meyerla
Sep 19, 2016Follower
Moving Between Router & Satellites
I have read about issues with other mesh networks when a user with a mobile device moves far away from the router or satellite they intially connect with. It seems often the device will try to stay ...
spewak
Sep 25, 2016Luminary
I would restart the Nestcam. It's all one SSID now.
JBMN
Sep 25, 2016Star
I did restart the NestCams (it was one SSID before too). And as of right now, they both have grabbed the orbi device furthest from them oddly. Wifi signal analyser says they shouldn't, but
To be clear, I don't put it on Netgrear/Orbi, just curious how devices make this decision with the shared SSID and if some devices are smarter than others.
- spewakSep 25, 2016Luminary
The Orbi's are able to differentiate between the needs of the different devices automatically.
From the site:
The tri-band WiFi that powers Orbi includes a dedicated 1.7 Gbps 5 GHz band that is used solely used for communication between an Orbi router and satellite. The other two WiFi bands are dedicated to the WiFi devices that you connect to your Orbi network.
The performance that you experience also depends on the devices that you are connecting to your network. In most circumstances, you can expect the following speeds:- Up to 400 Mbps for older devices using 2.4 GHz
- Up to 866Mbps for your newer mobile devices that support 5 GHz
