Phoenix125
Feb 14, 2025Aspirant
Moving from VM Busines to Vodafone
I'm in the process of switching from Virginmedia Business braodband to Vodafone Residential 910Mbps. I had the VM router in modem only mode and used my RBR50 as router with 3 RBS50 satellites which ...
Feb 14, 2025Guru - Experienced User
Try using the DMZ on the Vodafone router for the RBR50 thats in router mode, or configure the RBR 50 for AP mode. Disable the Vodafone routers wifi radios.
Phoenix125
I'll try it in AP mode (seems to be the easisest option).
Thanks
- FURRYe38Feb 14, 2025Guru - Experienced User
đ
- Phoenix125Feb 15, 2025AspirantI've got the RBS50 in AP mode and it's working as are the satellites.
Is there any reason why I can't or shouldn't keep the Vodafone WiFi up and running at the same time? I get better speed from that than I do from the Orbi- FURRYe38Feb 15, 2025Guru - Experienced User
Lots of noise and interferences between them.
Not sure what speeds you are seeing from the Orbi. Depending on devices support, connection, distances and which signal source your connected too, average speeds seen on 50 series would be between 300-500Mbps on 5Ghz. Could be lower with distances and building materials.
- michaelkenwardFeb 16, 2025Guru - Experienced User
Thanks
Easiest but maybe not the most effective.
I faced the same choice with a horrid BT HomeHub. I wanted to use my MK93 Mesh network with it. The DMZ turned out to be the best option. AP mode disables too much useful stuff.
If nothing else, DMZ mode makes it easier to access both the modem/router and the router without having to track down IP addresses for the AP and satellites.
Disclaimer: Just another user with time on their hands.
- Phoenix125Feb 16, 2025AspirantThere doesn't seem to be any way to enable DMZ on the Vodafone router. All I can see is something called Exposed Host which sounds unsafe.
Phoenix125 wrote:
There doesn't seem to be any way to enable DMZ on the Vodafone router. All I can see is something called Exposed Host which sounds unsafe.BT's modem/router hides the DMZ in the firewall settings.
It may sound unsafe, but what it probably means that the Vodafone box leaves it to the Netgear router to protect you. It is your choice as to which you expect to keep your protection up to date.
For serious defence, Netgear tries to sell you a subscription to Armor.
Does Vodafone have a user community forum that you can turn to for advice?
