Phoenix125
Feb 14, 2025Aspirant
Moving from VM Busines to Vodafone
I'm in the process of switching from Virginmedia Business braodband to Vodafone Residential 910Mbps. I had the VM router in modem only mode and used my RBR50 as router with 3 RBS50 satellites which ...
Phoenix125
I'll try it in AP mode (seems to be the easisest option).
Thanks
Feb 14, 2025Guru - Experienced User
- Phoenix125Feb 15, 2025AspirantI've got the RBS50 in AP mode and it's working as are the satellites.
Is there any reason why I can't or shouldn't keep the Vodafone WiFi up and running at the same time? I get better speed from that than I do from the Orbi- FURRYe38Feb 15, 2025Guru - Experienced User
Lots of noise and interferences between them.
Not sure what speeds you are seeing from the Orbi. Depending on devices support, connection, distances and which signal source your connected too, average speeds seen on 50 series would be between 300-500Mbps on 5Ghz. Could be lower with distances and building materials.
- Phoenix125Feb 15, 2025AspirantI assumed that would be the case. I've turned off WiFi on the Vodafone router but I have a new problem.
I said earlier that the satellites were working but they aren't. They show as connected in the Orbi app but devices connected to them have no internet access. Is it simply a matter of resynching them or is something more fundamental going wrong?
