Stins
Aug 16, 2020Aspirant
Moving Router - concerned about being too close
Hi all, Wondering if you can help me please. I'm currently at the end of my contract with ISP. I'm currently considering moving to another ISP with FTTP. The modem for this FTTP, is right in the ...
Stins
Aug 17, 2020Aspirant
Thanks for your reply!
At the minute yes, it would only be the one bedroom I can place it due to non-wireless devices being wired to the satellite. Would a change in the transmit power be an option if I do have issues?
I can't move the modem as it is a Fibre to the Property connection and I dare not even attempt to play around with the Fibre cable - reading on the internet that seems to be a big no no. Since I do not have my house wired up with ethernet it's not possible to then move the RBR50 router as it'll need to connect to that modem.
Mstrbig
Aug 17, 2020Master
I would wait until you are fully operational. I prefer to only reduce power as a last resort.
- CrimpOnAug 17, 2020Guru - Experienced User
Mstrbig wrote:
I would wait until you are fully operational. I prefer to only reduce power as a last resort.I agree, reducing transmit power affects every Orbi device, so the total area covered will shrink.
It is also pretty simple to move the satellites to other locations and "see what happens."
