SAOL
May 21, 2018Follower
Moving to Europe
I am moving to Germany. I purchased my RBR50 in the United States. Will the ORBI work in Germany? The voltage is higher there. Do I need an adapter, or a converter, or can I buy an ORBI plug there?
- BigBlue_007Aspirant
Here in Germany, most such devices including the Orbis are shipped with universal 110V-230V power supplies, so I could take mine and use it anywhere else with just a plug adaptor.
You would need to check the specs that are printed on your Orbi's power supplies. If it says "1x0V-230V" you're good to go, and you only need a plug adaptor.
- tagteamVirtuoso
My (purchased in the USA) AC adaptor for my RBK53 (RBR50 plus 2 Satellites) has "100-240V" written on the side.
That is fine as well of course :)
Germany uses 230V.
