Kacopers
Aug 12, 2021Tutor
Mr60 not connecting to spectrum modem
My modem fried in a storm this week so spectrum gave me a new modem. This one only has a single Ethernet output. When I attempt to connect it to my mr60, the router won't recognize anything is connect...
Kacopers
Aug 12, 2021Tutor
The modem recognizes something is connected when the Ethernet is connected to the "Ethernet" port of the mr60 but doesn't recognize anything is connected when the Ethernet is connected to the "internet" port of the mr60. I am not sure how it was set up. I factory reset the mr60 and am unable to proceed with setup because it doesn't detect internet.
I can move this to that forum if necessary. Thanks for the help.
CrimpOn
Aug 12, 2021Guru - Experienced User
Maybe someone who owns the MR60 will have had a similar experience and see your post there.
With a Factory Reset, the MR60 will be in router mode, which should work with an ordinary modem (only one ethernet jack).
How is the setup being done? (web interface or "app")?
- KacopersAug 12, 2021TutorI am doing set up via app
- CrimpOnAug 12, 2021Guru - Experienced User
Do you have anything that can connect directly to the modem's ethernet port (PC, Mac, Laptop?)
It is often worth a few minutes to verify that the modem is working correctly.
Unless you are required by the ISP to enter a user name and password to get connected, the MR60 should function without any setup at all.
Just plug it in, power it up and:
- It should begin broadcasting the WiFi name printed on the product label.
- The WiFi password should be what is printed on the label.
- If you connect a device using those credentials, it should get internet.
Does this not happen?
Of course, most of us want to pick our own WiFi name/password. (I always set it to match the WiFi router I am replacing so that all of my devices will connect automatically without being reconfigured.)
I connected everything and the MR60 doesn't receive internet from the modem. I am able to connect to the WIFI network that it broadcasts without the network has no internet. I think the issue is that the modem isn't recognizing the MR60. I tried it with a different router and had the same issue of the modem not sharing internet with the router, so it might be a modem sided issue.
