lw187
Sep 18, 2018Guide
mu-mimo setting for iPhone xs ?
Hi. My home currently does not have any mu-mimo devices but I see that the Iphone xs supports 2x2 MIMO for wi-fi.
should i enable mu-mimo on my router now?
1 Reply
Yes. You can enabled it and test it out. If it works and all of your other devices work, you can leave it enabled. If not, you can disable it.
