studdawg
Mar 29, 2020Aspirant
Multilogin notice requiring reentering password constantly
Ok, started a new thread. I have an RBR50 with an RBS50 and RBS20. The app works fine but when I use the browser GUI, I can get one or two mins of work done and then I get the pop up saying that I ...
CrimpOn
Mar 29, 2020Guru - Experienced User
The "app" and a browser from a different device have different IP addresses, and the Orbi will detect that. I believe the app can connect to the Orbi two ways: on the local WiFi or via the internet "cloud".
How about this. TURN OFF the device which the app is running on and work on the Orbi using the web interface.
Please note that one annoying feature of the web interface "Attached Devices" page (which you may be using) is that it pops up the login box periodically. I compensate for this by having my web browser remembe the Orbi password so all I have to do is hit enter.
It is "super annoying" when I have multiple windows open in the browser (such as right now). I am busy typing a post for the Orbi user forum and forget that Attached Devices is open in another window. That window pops up while I am typing and I type over "admin".
- studdawgMar 29, 2020Aspirant
Thanks. I thought your solution was working but just got the popup. My iphone was off before I logged in. Sigh...
- CrimpOnMar 29, 2020Guru - Experienced User
studdawg wrote:Thanks. I thought your solution was working but just got the popup. My iphone was off before I logged in. Sigh...
Please confirm, which popup? There are two: (1) the Attached Devices page wanting to authenticate every few minutes, and (2) a notice that another device is connected and should it be dropped or not.
I just now timed my Orbi Attached Devices page. Orbi pops up a request to authenticate every 5 minutes. (I sat through two with a stopwatch running on my phone. Any more and I would have gone into a trance.) Hmmm. There is probably a timer set to 300 seconds buried somewhere in the Orbi parameter file. I'll look.......
