JoeM845
Apr 09, 2020Luminary
Multiple APs. RBR50 losing connection
Does an RBR50 in AP mode have a problem if there is also a non-ORBI AP on the same LAN in the same area withj the same SSID? For the past week I am getting some strange connection issues that show u...
- Apr 17, 2020
Don't want to lower the new AP power. I am in the process of moving the new APs in. They can work with VLANs for better security.
I changed the SSID on the new AP with no change in channels. Worked.
Thanks
JoeM845
Apr 17, 2020Luminary
Thanks
Apr 17, 2020Guru - Experienced User
Glad its working now. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
