FrustratedUser3's avatar
Oct 04, 2020
Multiple configuration updates (Flashing white lights) per day
I am a work at home and gamer... My orbi FREQUENTLY updates (flashing white lights). I would say once every 2 days or so and sometimes more freqently. The updates also  happen at the worst times.. Like being on important conferences call or critical juctions during gaming. Because there isn't a way to disable auto-updates, nor is there a way to set an update/maintiance window, orbi continues to kick me off whenever it feels like it. This is beyond frustrating and I'm either going to find a solve, or purchase a different product, plus leave MULTIPLE warnings to future users that it is not the solution that they are looking for.
I am running V2.7.0.70.. I've also run V2.5.2.4.. I'm seriously at a loss here. I've seen some post stating that they will allow users to disable auto-updates, but I've yet to find this option (I don't think it exists).
1 Reply
  • FURRYe38's avatar
    Flashing WHITE doesn't mean the RBR is updating:
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    Has a power off for 1 minute then back on been performed since last update?
