luivan
May 14, 2020Follower
Multiple connected devices Orbi RBR40
I have the rbr40 orbi with 4 satellites and have more than 300 devices connected and growing, most swiches, plugs, nest etc, person users just 8 will and I start having problems of connection droped...
May 14, 2020Guru - Experienced User
Default IP address pool is 192.168.1.1 to .254.
1 is already using by the router and .255 is used by broadcast protocols(Standard Networking Policy), thus you now have 253 IP addresses available. Home class routers only support 255 IP addresses. Thus ran out of IP addresses to use due to having more than 300 devices connected to 1 DCHP server pool that only supports 253 addresses. This applies to all home class routers including Orbi AX.
Not sure if Orbi Pro will be of any help.
You may need to contact NG support to see about this or ask about this over in the Orbi pro forum:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
