ah42
Feb 01, 2018Tutor
Multiple devices can't connect to Orbi
I just bought and set up the RBK30 Orbi system. I have 3 devices that won't connect to the wifi network - A 2015 Macbook Pro, LG G6, and Asus 3S 10 tablet. The macbook just keeps saying "invalid pass...
DarrenM
Feb 05, 2018Sr. NETGEAR Moderator
When you bought the RBK30 did you use the same SSID network name as your old router setup? if so did you remove that network from the wifi settings of those devices?
DarrenM
- ah42Feb 05, 2018Tutor
So I tried to use the same SSID to avoid re-setting up my ip cameras and other connected devices, but it just wouldn't work with my devices. Even though I made sure to forget the old network from the wifi settings, it still wouldn't work. Ended up having to just make a new SSID and now everything works as it should.
