pfajr
Mar 22, 2022Follower
Multiple Devices
I had two homes and now just one. So I have two sets of Orbi AC3000 systems; 2 - RBR50v2 2 - RBS50v2 1 -RBR50 Since this is what I have for the new home I would like to use them. I have a spect...
Mar 22, 2022Guru - Experienced User
Having too much wifi could be a bad thing...
You can run 1 RBR as your main host router with the RBS, The other RBR could be used in wired APs as long as distances and channels were far apart. You might also run into a situation where the RBS may attempt to connect to the other RBRs in AP mode. Something to avoid.
