TPE
Aug 17, 2022Follower
Multiple homes
I have two homes, how can I use my Orbi app for both??
KevinLiT
Aug 17, 2022NETGEAR Moderator
Hello TPE,
Welcome to the NETGEAR Community!
I understand that you would like to manage more than one Orbi system using your Orbi app.
First, navigate to "Set Up A New Orbi System then follow the prompts. After your new Orbi system has been successfully set up follow the steps listed below.
From your Orbi app home screen please do the following:
- Navigate to the three lines at the top left of the screen.
- Tap the arrow on the far left located next to your device name.
- From there you will see your products page.
- Tap the product that you like to access.
Best,
Kevin
Community Team
