DarioVig
Sep 10, 2020Aspirant
Multiple internet issue with ORBI
Hi all, in the past month i started having multiple issues with ORBI tried multiple things but nothing worked. 1) When i stream (video / calls) other services disconnect (e.g. Email browsing). I...
Sep 10, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If there is a built in router and wifi here, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
DarioVig
Thanks i ll start answering some questions at my best knowledge. Let me know if it is sufficient.
1) Firmware V3.5.12_1.0.8
2) I am connecting the ORBI Router/Modem CBR40 directly to the cable wall outlet. I am not connecting the ORBI Router/Modem to any XFINITY Modem. This should avoid the double NAT right?
3) Right now i disabled all the Satellites and testing the connectivity basically at 1 foot from the main ORBI Router.
- MstrbigSep 10, 2020Master
DarioVig wrote:Thanks i ll start answering some questions at my best knowledge. Let me know if it is sufficient.
3) Right now i disabled all the Satellites and testing the connectivity basically at 1 foot from the main ORBI Router.You say you are connecting directly to the wall plug. Is it COAX or Network cable?
What model Xfinity modem do you have? Double NAT is going to depend what's on the other end of the wall cable.
- DarioVigSep 10, 2020Aspirant
Thanks!
1) using COAX
2) understood. if i get it correctly, since i am in a townhome I am still connected with the centralized Xfinity MODEM (which i dont know the number and model but i can figure it out ), i might still have a double NAT issue. Correct?- MstrbigSep 10, 2020Master
DarioVig wrote:
1) using COAX2) understood. if i get it correctly, since i am in a townhome I am still connected with the centralized Xfinity MODEM (which i dont know the number and model but i can figure it out ), i might still have a double NAT issue. Correct?
No, if a townhome complex, Xfinity should have a centralized tap requiring an ISP type DOCSIS modem, (your Xfinity), which your Orbi is.
Did you contact Xfinity to register the Orbi when you intstalled it? Most ISPs require it, in order to configure the DOCSIS modem portion of your modem/router for IP, DNS and Plan speed.
- FURRYe38Sep 10, 2020Guru - Experienced User
Ok, I didn't see the model listed. I thought you had a RBK system. Sorry about that.
Let us know how it goes wtih out the RBS on line.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
3) Right now i disabled all the Satellites and testing the connectivity basically at 1 foot from the main ORBI Router.- DarioVigSep 10, 2020Aspirant
Thanks Furry, i tried all of that but still same issues holds
