TheJam's avatar
TheJam
Multiple IP Address Issue Using Orbi in AP Mode and XR1000 as Router
Hi there,
I'm having an issue at the moment where I have an XR1000 set up as my router with an RSR50 connected to it via Ethernet and setup in AP mode - 2 Satellites are also connected. I have the Orbi set to use a static IP address to the XR1000 which works fine. However, I've noticed that the Orbi is assigning IP addresses to devices, then my XR1000 is using another IP address for it. I tried reserving static IP addresses for devices connected to Orbi but still have the same issue.
I'm a bit confused, my understanding was that DHCP is disabled in AP mode and it uses the Router to assign IP addresses. Is there something I'm missing? I've updated the Orbi firmware to the latest version v2.7.4.24, reset the Orbi Router and Satellite's back to Factory settings and reapplied all my settings manually.
Thanks in advance for any help,
TheJam
  • CrimpOn's avatar
    CrimpOn
    This is correct. In AP mode, the Orbi is not supposed to issue IPs.
    Do you observe the devices changing IPs?
    • TheJam's avatar
      TheJam
      Hey, it took awhile actually but finally changed to the IP address I expected it to. I don't have settings for DHCP Lease Renewal on my Router and I'm not sure what the default is but I'm guessing it's going to due to that taking awhile
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello TheJam,
        I understand that your devices are being assigned an IP address from the Orbi system that is configured for AP mode. CrimpOn is correct, in AP mode router functions are disabled.  The Orbi device will not able to assign IP addresses. Toggle the Orbi device from AP mode -> router mode ->AP mode.
        Let me know if you have any additional questions!
        Best,
        Kevin
        Community Team
