sojourn_out
Aug 25, 2020Aspirant
Multiple Network names/passwords
Hello! I own a 6,800 sq. ft, 8 unit. Airbnb property. I have an Orbi router (RBR20) with 2 satellites (both RBS20), because the website showed me that this mesh system could cover 6,000 sq. ft. H...
Aug 25, 2020Guru - Experienced User
You may need to look into a business class system for your needs. Orbi home products is based on a signal wifi SSID and single PW. Something that you won't be able to use for your needs. Orii 20 series only supports up to 6000sq ft and not beyond. Somnething a 50 series would do better however again, would not work for you wifi configuration needs.
You might try Orbi pro however not sure if that will support your needs either. I recommend looking into business class wifi systems for your needs.
