sojourn_out
Aug 25, 2020Aspirant
Multiple Network names/passwords
Hello! I own a 6,800 sq. ft, 8 unit. Airbnb property. I have an Orbi router (RBR20) with 2 satellites (both RBS20), because the website showed me that this mesh system could cover 6,000 sq. ft. H...
Mstrbig
Aug 25, 2020Master
sojourn_out wrote:Hello!
However, all 8 units do not receive the same coverage. I need to get some extra satellites or Orbi Voice devices, but I am in need of help with this.
Our main goal is to have a different wifi name and password for each Unit.
Ex. Unit 1s wifi name would be Sojourn1, PW: SojournUnit1
Unit 2; Sojourn2; SojournUnit2and so on.
Is there a way I can do this with multiple routers or satellites?
What would be the best recommendation?
Thanks for taking time to help!
To do this correctly you would need Enterprise APs controlled through a central management system, which could get quite expensive. Wiring the building and adding multiple routers may have interference issues, because of 8 routers in a small area.
Since the RBR20 is a less powerful Orbi system with less coverage, it would be cheaper to get a more powerful Orbi system like the RBK53 and add more satellites to it. Depending on the layout of the building, 1 router and 4 satellites may cover it. However you will have 1 WIFI SSID for main and 1 WIFI SSID for guest.
sojourn_out
Mstrbig Is this what you would recommend then?
- MstrbigAug 25, 2020Master
sojourn_out wrote:Mstrbig Is this what you would recommend then?
Correct. The best solution is to stay with a more powerful Orbi system, forget the multiple SSIDs, as the expense can get costly, and add satellites as needed.
- sojourn_outAug 25, 2020Aspirant
What I find interesting is that when I reached out about the best Wifi Mesh System, that would cover over 6000 sq. ft. I was told to get the RBK20.
But you are telling me that this mesh system does not provide that coverage?
sojourn_out wrote:What I find interesting is that when I reached out about the best Wifi Mesh System, that would cover over 6000 sq. ft. I was told to get the RBK20.
The RBK23 - 1 router 2 satellites covers "up to" 6000 Sq Ft. <-fine print will show perfect conditions, no obstructions, walls, wiring, etc.
So with a multi unit building, like yours, with lots of wall, wiring, etc, the signal can get squashed.
I over compensate when installing a wireless mesh system, which is why I suggested the RBK53 system and an extra satellite.
