sojourn_out
Aug 25, 2020Aspirant
Multiple Network names/passwords
Hello! I own a 6,800 sq. ft, 8 unit. Airbnb property. I have an Orbi router (RBR20) with 2 satellites (both RBS20), because the website showed me that this mesh system could cover 6,000 sq. ft. H...
sojourn_out
Mstrbig Is this what you would recommend then?
Mstrbig
Aug 25, 2020Master
sojourn_out wrote:Mstrbig Is this what you would recommend then?
Correct. The best solution is to stay with a more powerful Orbi system, forget the multiple SSIDs, as the expense can get costly, and add satellites as needed.
- sojourn_outAug 25, 2020Aspirant
What I find interesting is that when I reached out about the best Wifi Mesh System, that would cover over 6000 sq. ft. I was told to get the RBK20.
But you are telling me that this mesh system does not provide that coverage?
- MstrbigAug 25, 2020Master
sojourn_out wrote:What I find interesting is that when I reached out about the best Wifi Mesh System, that would cover over 6000 sq. ft. I was told to get the RBK20.
The RBK23 - 1 router 2 satellites covers "up to" 6000 Sq Ft. <-fine print will show perfect conditions, no obstructions, walls, wiring, etc.
So with a multi unit building, like yours, with lots of wall, wiring, etc, the signal can get squashed.
I over compensate when installing a wireless mesh system, which is why I suggested the RBK53 system and an extra satellite.
