jgrb_LA
Jan 05, 2021Aspirant
Multiple Orbi network systems in the neighborhood - known issues?
Hello, I am the 'IT / Security' volunteer for our building HOA. I am NOT a professional but am comfortable with tech in general so have been nominated :) I am currently working on a solution for ...
jgrb_LA
Jan 11, 2021Aspirant
Thanks for your reply FURRYe38 and makes sense on the power settings.
Also, I have seen in some of your previous posts that you do recommend setting manual channel 1, 6 or 11 on 2.4Ghz - do you still recommend this?
Jan 11, 2021Guru - Experienced User
I would try them and see. If you can find a wireless anyalyzer to install on a pad, these will give you some channel and signal information on what your neighbors are using. You can adjust the channels accordingly to help avoid what your neighbors maybe using.
jgrb_LA wrote:Thanks for your reply FURRYe38 and makes sense on the power settings.
