jaisingh
Mar 23, 2020Aspirant
Multiple Orbi Routers in one network
Hello, I have following question: I have a 2 story home and I am afraid there will be no good connection between the floors if I use 1 router and multiple satellites. There is an ethernet cable ...
Retired_Member
Mar 23, 2020
jaisingh wrote:
Hello,
I have a 2 story home and I am afraid there will be no good connection between the floors if I use 1 router and multiple satellites. There is an ethernet cable connecting the floors. So my question is, if it is possible to use 2 routers with 2 satellites each. One set per floor. Each router connected via ethernet. But still functioning as one single network.
Thx guys
Yes you can, however one must be in the AP while one handles the DHCP stuff.
Have you tried just the Orbi router in place?
jaisingh
I haven't bought it yet as I only have experience using 1 Router. I would let another Router handle DHCP, so the Orbi Routers would just be there as APs and so the satellites can connect to them
