CaraBethP
Apr 13, 2019Tutor
Multiple problems- RBR-50
Good morning- My tech experience level is medium. I was a tech director of a school but never worked with wireless. I have several questions. Hope someone will have patience with my detailed explanat...
- Apr 16, 2019
I finally have my problem fixed. It was all Spectrum and they had to visit 5x to get stuff working. The final quality control guy told us that Orbi is the best technology to use on a home network.
Apr 13, 2019Guru - Experienced User
For ease of access to the Orbi, you can do a factory reset and with a wired PC connected to the Orbi can walk thru the setup wizard. You can do this even with out the Orbi connected to the modem.
IF your modem already has a router and wifi built in, youll need to try one of the options with the modem first, before connecting the Orbi.
You may want to ask your ISP for help with the modem...
