huntewe's avatar
huntewe
Multiple problems- RBR-50
I JUST SET UP THE ORBI RBR50 DEVICE AND I CANNOT GET MY PELOTON APP OR PANDORA TO RUN ON MY IPHONE WHEN I CONNECT TO THE ORBI NETWORK.  ANY SUGGESTIONS?
  • SW_'s avatar
    SW_
    May 09, 2019
    huntewe wrote:
    The Orbi system was in router mode, I changed it to AP Mode.  No difference.  I turned off the wifi on Uverse router and it is now working.
    Just curious, did you happen to use the _same_ SSID for both Uverse router and Orbi?
