huntewe
May 08, 2019Aspirant
Multiple problems- RBR-50
I JUST SET UP THE ORBI RBR50 DEVICE AND I CANNOT GET MY PELOTON APP OR PANDORA TO RUN ON MY IPHONE WHEN I CONNECT TO THE ORBI NETWORK. ANY SUGGESTIONS?
SW_
May 09, 2019Prodigy
huntewe wrote:The Orbi system was in router mode, I changed it to AP Mode. No difference. I turned off the wifi on Uverse router and it is now working.
Just curious, did you happen to use the _same_ SSID for both Uverse router and Orbi?
huntewe
May 10, 2019Aspirant
I used different SSIDs for the UVerse Gateway and ORBI
