emaniat
Mar 12, 2018Aspirant
Multiple SSIDs
Hi, I am really leaning towards the Orbis since the layout of my house would require a mesh network. I've used APs with range extenders in the past without good results. I do have a questi...
- Mar 13, 2018
Yes you can have three SSIDs. While you can change channels, that's not the same thing as assigning bands (2.4 vs 5 GHz) to each SSID. I'm pretty sure you can't do it, just like you can't do it with the non-pro Orbi. (Other than the telnet workaround.)
If you want to truly isolate your IOT devices and you want separate SSIDs for 2.4 and 5 GHz bands, you would be better off with something like a Ubiquiti Unifi AP and one of their VLAN-aware routers.
emaniat
Mar 13, 2018Aspirant
Thanks for the info. Definitely answers my question on the bands. I'll look into the Ubiquiti Unifi setup. Not sure if the wife would like all of the networking equipment in our living room. As for that matter since I work with this stuff all day long I don't know if I'd like it in the living room either. Lol...
Is their stuff easy to work with? Two of my friends whom are network engineers have the Unifi's at home and recommended them. I was just trying to find something in the middle that could be easy on the eyes and yet do it's job.
st_shaw
Mar 13, 2018Master
The APs and controller are esy to work with. The routers require a bit more learning. A fair amount of study online and on their forums is required to get the most out of them.
I have the APs on top of furniture and find they are almost invisible.
