valisorell
May 16, 2019Follower
multiple WNDAP360 in one room, 100+ devices
I have a shed that I use as a home office; it's about 100' from the house.
I have an Orbi RBR50 with an RBS50 satellite in the house, and the reception in the shed is signifcantly slower than in th...
SW_
May 16, 2019Prodigy
valisorell, 100' is a bit too far b/c recommended max distance between them is 70' for optimal performance. At 100', you might get degraded performance, which might be good enough depending on your use case. If you're able to recieve signal in the shed with your current WiFi cards, it won't be a problem with a new RBS50. You'll more likely to get better performance with RBS50 due to Orbi more powerful 4x4 backhaul attena than your current WiFi cards.
Before getting a new RBS50, find a long cable and move the Orbi to the the current Satellite location. Then move the Satellite into the shed. Start testing and see if the performance meets your need. If not, try to play around with Orbi placement. If all else fails, you might have to look into running a long cable to your shed rather than a new RBS50.
