valisorell
May 16, 2019Follower
multiple WNDAP360 in one room, 100+ devices
I have a shed that I use as a home office; it's about 100' from the house.
I have an Orbi RBR50 with an RBS50 satellite in the house, and the reception in the shed is signifcantly slower than in th...
CrimpOn
May 16, 2019Guru - Experienced User
100 ft is not trivial. The product Netgear makes specific to this need is the RBS50Y (outdoor). Here's the link:
Does this look like your situation?
"Radio stuff" depends on so many factors, such as the material the shed is made of, wall construction, obstacles, etc.
A number of community members have described using Ubiquiti products to create a point-to-point link between a main building and a separate structure (the Ubiquiti link basically acts like an ethernet cable). Search the forum for "Ubiquiti" for examples.
