NortheastGuy
May 02, 2018Star
Multiple XBOne Consoles, no longer connecting
Firmware: V2.1.4.10
Since upgrading my router and satellite two nights ago, I'm now no longer able to have both my XBox Ones connected to the Internet at the same time when wired. XB1 is wired to...
May 02, 2018Guru - Experienced User
Have you set up IP address reservations for the consoles on the router?
You may have conflicting IP addresses. Be sure to reboot the router, right after you do this, connect the ethernet cables to the consoles and hold the POWER button on the consoles until the consoles turn OFF. After the router reboots, turn on the 1st console an check networking settings. Log into the routers web page and set up and IP addresss reservation ON the router. Save settings. Turn on the next console and set up an IP address reservation for the console ON the router. Save settings then Apply. The router will reboot again.
FYI:
http://badmodems.com/Forum/viewtopic.php?f=6&t=21&sid=21356e1aff679a087b40998c1c68b805
NortheastGuy
May 02, 2018Star
Yes, both have static IPs.
I also have NAT Filtering under Advanced->WAN set to Open, also didn't help. What's throwing me off is if I put them on WIFI (or just one of them on WIFI) it works. Its when I have both wired that it fails.
