NortheastGuy
May 02, 2018Star
Multiple XBOne Consoles, no longer connecting
Firmware: V2.1.4.10
Since upgrading my router and satellite two nights ago, I'm now no longer able to have both my XBox Ones connected to the Internet at the same time when wired. XB1 is wired to...
NortheastGuy
May 02, 2018Star
Sorry, I should have clarified. I have the IP address reservations on the router, not on the consoles.
May 02, 2018Guru - Experienced User
Hold down the power button on each console until they turn off. This should clear out any networking caches. Then reboot the router. Power on 1 of the consoles and check connection. Do they get the reserved IP address in Network Settings on the console?
You might need to remove the reservations. Seems like something is getting hung up in DHCP...
