jeberhawk
Apr 29, 2022Tutor
Musings of an Orbi Firmware Update
I own an Orbi RBR50v2 with three satellites. I’ve often checked for firmware updates via my iPhone’s Orbi app. Before the update, the firmware version was V2.7.3.22. Each time the iPhone app informed...
KevinLiT
Apr 29, 2022NETGEAR Moderator
Hi jeberhawk,
I understand that you were able to update your RBR50 to the latest released firmware v2.7.4.24. There is no need to factory reset your device once it has successfully been updated.
Firmware updates are pushed out in increments over a period of time. The reason your Orbi app did not detect the updated firmware is because the firmware was not pushed out to your device. However, it is still available for use via manually update.
Best,
Kevin
Community Team
