wilderw
Dec 02, 2016Guide
Must an Orbi system be manually synced following any power outage
Power cycling either the router or satellite leaves the satellite in a constant blinking state (slow white pulse on top circle) until I manually hit the sync button on router then satellite. Is t...
Mikey94025
Dec 02, 2016Hero
I haven't had to manually sync my Orbi base or satellite after a power outage or rebooting. I did notice that my satellite was flashing white but it recovered itself automatically. Did you wait at least 10-15 minutes to see if it rejoins automatically?
- wilderwDec 03, 2016Guide
I waited a significant period of time (which to my thinking should not require more than a minute or two at most) but I will try a 10-15 minute wait to see if that makes a difference. A 10-minute sync to establish backhaul does seem slow to me.
I did forget to mention in my original posting, I am at latest firmware on router and satellite.
Bill
- KdraganDec 03, 2016Initiate
I'm amazed how the forum's response to issues seems to be "that hasnt happened to me, so it must not be an issue...". Wilderw....yes i have the exact same issue (a fatal flaw in the product).
Further Update:
I waited the suggested 15 minutes. Attached devices on the router will (within a reasonable time interval) show the satellite is connected and devices will make a connection to the satellite - but the blinking white light (satellite only) continues without cease.
I manually reset router and satellite to factory settings and the problem persists (which may simply be an issue that the satellite fails to extinguish the blink post restart).
I can get the lights to extinguish by pressing sync buttons on router and satellite - but the issue recurs the next time either device power cycles.
It's not a showstopper for me - but suggests a bug perhaps that might be corrected next firmware release?
For the users that don't see this behaviour - might it be a difference between router mode and AP mode?
Bill
