wilderw
Dec 02, 2016Guide
Must an Orbi system be manually synced following any power outage
Power cycling either the router or satellite leaves the satellite in a constant blinking state (slow white pulse on top circle) until I manually hit the sync button on router then satellite. Is t...
wilderw
Dec 03, 2016Guide
I waited a significant period of time (which to my thinking should not require more than a minute or two at most) but I will try a 10-15 minute wait to see if that makes a difference. A 10-minute sync to establish backhaul does seem slow to me.
I did forget to mention in my original posting, I am at latest firmware on router and satellite.
Bill
Kdragan
Dec 03, 2016Initiate
I'm amazed how the forum's response to issues seems to be "that hasnt happened to me, so it must not be an issue...". Wilderw....yes i have the exact same issue (a fatal flaw in the product).
