wilderw
Dec 03, 2016Guide
Must an Orbi system be manually synced following any power outage
Power cycling either the router or satellite leaves the satellite in a constant blinking state (slow white pulse on top circle) until I manually hit the sync button on router then satellite. Is t...
DarrenM
Dec 05, 2016Sr. NETGEAR Moderator
Hello WilderW
This could be a bug in AP only my orbi is used as a router and does not have that issue I will try to set it up as AP and try to replicate the issue you are having. The only other thing I can think of is a signal strength issue may just be out of range to auto sync back up you could test that by bringing the satellite closer and see if it shows the same behavior but if that is difficult to do do not worry about it I will try to test mine.
DarrenM
wilderw
Dec 06, 2016Guide
DarrenM: Thanks for your comments and offer to test AP-only mode - I'll be interested in your results. As I reported earlier - even with the router and satellite close together - the slow white blink on the satellite never extinguishes. However, the connection is completed within a minute or so and devices do connect to the satellite.
For the moment my satellite sits on a shelf unsused due to issues with the Ring Doorbell. I'm hopeful a future firmware upgrade from Orbi or Ring's side might correct that issue and let me redeploy the satellite.
Bill
- rhester72Dec 06, 2016Virtuoso
As a datapoint, I took a power hit a few weeks ago on v1.3 and the sync happened on its own from the opposite end of two floors - it was seamless, no manual intervention required.
Rodney
