wilderw
Dec 03, 2016Guide
Must an Orbi system be manually synced following any power outage
Power cycling either the router or satellite leaves the satellite in a constant blinking state (slow white pulse on top circle) until I manually hit the sync button on router then satellite. Is t...
DarrenM
Dec 08, 2016Sr. NETGEAR Moderator
Hello wilderw
I am not seeing a issue either you may want to contact support could be a issue with that satellite.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
wilderw
Dec 14, 2016Guide
Update: I can report that this problem persists with the V1.4.0.18 firmware (applied to both satellite and router). Recap - with my devices configured in Access Point mode, the satellite shows an indefinite slow white blink post startup. As far as I can tell, the satellite comes up, syncs and is functional with attached devices so this is an indicator issue rather than an actual performance issue.
A manual sync will extinguish the light.
