wilderw
Dec 02, 2016Guide
Must an Orbi system be manually synced following any power outage
Power cycling either the router or satellite leaves the satellite in a constant blinking state (slow white pulse on top circle) until I manually hit the sync button on router then satellite. Is t...
Tri2243
Mar 03, 2017Aspirant
I have same issue anytime the power blips my orbi router and first satellite connect within a few minutes. My second satellite will flash white for hours if I don't manually sync. I have even placed the satellite next to the router and moved it to other locations with no obstructions with no change. I had the issue on 1.4 and 1.5 firmware.
