wilderw
Dec 03, 2016Guide
Must an Orbi system be manually synced following any power outage
Power cycling either the router or satellite leaves the satellite in a constant blinking state (slow white pulse on top circle) until I manually hit the sync button on router then satellite. Is t...
Tri2243
Mar 03, 2017Aspirant
Also unplugged the "good satellite" to see if it was a issue adding a second satellite and did a reset and "bad" satellite still won't connect.
Butch1326
Mar 04, 2017Star
I hooked up a UPS device to the satellite because of the manual sync issue after power outages. I can also confirm this is an issue. I am running Orbi in AP mode.
