andy_HK
Oct 24, 2018Aspirant
My AC2200 connection to satellite became POOR
I just buy the AC2200 for just one month. Everything is fine until today, the connection between main and satellite sudden dropped from 5G to 2.4G and the connection from satellite to device droppe...
Oct 24, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
andy_HK
FW is V2.2.1.210.
- FURRYe38Oct 24, 2018Guru - Experienced User
Let us know about the other suggestions as you go.
- andy_HKOct 24, 2018Aspirant
It is connected to service provider fiber modem providing 1Gbps. Speed test still at 9xxM.
My host and satellite is just 10 ft away with line of sight through some window only. It can see each other via glass.
I am using a Wifi analysis, 2.4G, I am at channel 2, other channel 3-10 is very crowded. 5G is auto.
I have no experience to enable and disable all these features.
The strange thing is both set working well in the last one month and just starting today.
I just wonder if the satellite is already downed or the 5G backhaul channel is down such that all connection via satellite is downed.
The main host unit still work fine at other phone/ipad.
What is the model# and Brand of this modem?
What is the distance between the Orbi router and it's satellite from each other.
I recommend channel 1 or 11, 13 if you see this channel.
- BullyterrierOct 24, 2018StarThere does seems to be a bug re satellites that have not moved and been fine for months suddenly showing as poor connection.
I’ve had this after power cut and after reboot (latest firmware).
Only way I’ve resolved it is to:
Switch off satellite.
Use router gui to remove the ‘disconnected’ satellite.
Factory reset satellite
Use the add satellite function in router gui.
Just a reset of the satellite doesn’t work - it just comes back as if not reset. The remove process at the router does seem to reset it though (I suspect otherwise the first thing the router does is sync the satellite as it was pre reset, including whatever the bug is).
