andy_HK
Oct 24, 2018Aspirant
My AC2200 connection to satellite became POOR
I just buy the AC2200 for just one month. Everything is fine until today, the connection between main and satellite sudden dropped from 5G to 2.4G and the connection from satellite to device droppe...
Oct 24, 2018Guru - Experienced User
What is the model# and Brand of this modem?
What is the distance between the Orbi router and it's satellite from each other.
I recommend channel 1 or 11, 13 if you see this channel.
Bullyterrier
Oct 25, 2018Star
There does seems to be a bug re satellites that have not moved and been fine for months suddenly showing as poor connection.
I’ve had this after power cut and after reboot (latest firmware).
Only way I’ve resolved it is to:
Switch off satellite.
Use router gui to remove the ‘disconnected’ satellite.
Factory reset satellite
Use the add satellite function in router gui.
Just a reset of the satellite doesn’t work - it just comes back as if not reset. The remove process at the router does seem to reset it though (I suspect otherwise the first thing the router does is sync the satellite as it was pre reset, including whatever the bug is).
- FURRYe38Oct 25, 2018Guru - Experienced User
What the current setting on the Daisy chain setting on the UI?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Yes when you reset the satellite, it goes back to factory settings and has to be re-synced.
Just a reset of the satellite doesn’t work - it just comes back as if not reset. The remove process at the router does seem to reset it though (I suspect otherwise the first thing the router does is sync the satellite as it was pre reset, including whatever the bug is).- andy_HKOct 27, 2018Aspirant
Sorry for the late update as it was really busy in the last few days.
Thanks for all the reply and suggestion.
I had tried to reset to factory default setting as well as power down , then set to country of usage from Default (Austrilia) to USA, then Enable BEAMFORMING, Enable Fast Roaming per local Netgear Technical Support.
I cannot go back to high speed transmission any more. I just 20M-40M instead of last one month of 280-300M. Besides the Gigabyte wired connection always show dis-connection, too.
As a conclusion, the setting shown the connection between Host to Satellite-1 although showing back 5G or even GOOD connection after the Reset and change setting. The speed still keep low at only 10% as compare to last one month. Further the Wired Gigabyte Ethernet port of Satellite-1 sometimes shown dis-connection.
I suspect the Satellite-1 5G antenna is not working well with HOST any more after one month of service.
- FURRYe38Oct 27, 2018Guru - Experienced User
You may want to contact NG support and ask about an RMA...This unit seems faulty.
