MelQ
Apr 01, 2021Aspirant
My App nor my computer can find the Orbi Wifi.
My Orbi was working perfectly fine until yesterday. Internet modem is working perfectly. The App on my phone cannot find the Orbi. When attempting to join the Orbi Network, it says I cannot join. My...
CrimpOn
Apr 01, 2021Guru - Experienced User
MelQ wrote:My Laptop cannot find the wifi of the Orbi, even after factory reset. And i tried to hardline the Orbi to my laptop and was unsuccessful. I have no idea what to do at this point.
After a Factory Reset the Orbi WiFi will be set to the WiFi SSID/password that is printed on the product label.
Can you please describe the sequence of ring light patterns as the router boots up?
The total sequence takes just under 3 minutes and involves the white light going ON..OFF..ON..OFF for a while, then fading on, fading off, fading, fading off for a while and then finally going out.
MelQ
That is exactly what it does! on off on off, slow fading and then it turns off. even after that, my phone nor my computer can see the orbi.
- CrimpOnApr 01, 2021Guru - Experienced User
MelQ wrote:That is exactly what it does! on off on off, slow fading and then it turns off. even after that, my phone nor my computer can see the orbi.
That is just CRAZY. I often start up an Orbi that is not connected to the internet at all and the WiFi signal appears every time, "ORBI" plus two digits. If there is no WiFi after a Factory Reset and what appears to be a normal startup, I have no idea what else to try.
If it is less than one year old, Netgear should replace it.
- MelQApr 01, 2021Aspirant
My warranty expired 3/1 :smileysad:
actually, as I am looking at it, it is a solid white, fades in and out, but the white stays on longer.
- FURRYe38Apr 11, 2021Guru - Experienced User
Any progress on this?
MelQ wrote:My warranty expired 3/1 :smileysad:
