Chris_NZ's avatar
Chris_NZ
My emails won't download any embedded images using the Orbi as primary Wifi connection
I have just purchased an Orbi router and 2 Satelittes. I now connect my home laptops and the kids various devices to this as the primary home wifi connection. Unfortunately  the kids can't view their...
  • ekhalil's avatar
    ekhalil
    Jan 01, 2019
    Chris_NZ wrote:
    fantastic thanks !!!
    The model is Chorus Optical Network Termindal - Model Type 200
    Cheers and Happy New Year
    Chris
    Thanks. This looks to be just a modem (ONT) without any routing functionality so you should be fine to use Orbi as router.
    The issue of not being able to download images can then be just a throughput issue. Please check the following:
    - Can you please swap the cable between the ONT and Orbi to exclude any cable issues. May be you have done that already? ;)
    - Do you see the issue only with wireless device or also with wired devices?
    - What 2.4 GHz and 5GHz channels are you using? Please check this by logging in to orbilogin.com.
    - What wired devices do you have connected to Orbi's LAN ports? Do you have any wired speakers?
    Happy New Year to you too :)
