TMAMA33
May 21, 2018Follower
My Iphone 6 plus + Orbi = Nothing
Hello! It appears that I am connected, but am not.
Works on every other device in the home but mine.
Any thoughts? Frustrating for sure.
May 22, 2018Guru - Experienced User
What iOS version are you using? I'm using 11.2.5 on my 6sP.
Is the phone getting an IP address?
Set up an IP address reservation for the phone ON the router?
What version of FW is loaded on the Orbi?
Temporarily disable WPA on the Orbi router. Try to connect the phone to the router and gain internet access. Does this work?
Then re-enable WPA2 and AES only. Forget the network on the phone then reconnect the phone using the SSID and PW.
