AATCT
Mar 26, 2020Tutor
My Macbook Air is not connecting with my wifi router
I recently repaired my Macbook Air and now only can connect to my router in one area of the flat. I have two other Router satelites but not able to connect to them. The wifi signal will drop if I mov...
Mar 26, 2020Guru - Experienced User
What Mfr and model Orbi router are you using?
Do other devices conenct to the system ok?
- AATCTMar 27, 2020Tutor
It is the ORBI RBR 20. This Macbook Air is the only that has a problem. I have another Macbook Pro and Ipad all work perfectly.
My macbook air screen was damaged and I replaced it. After replacing it, it only stays connect to the router in my study and the moment I stepped out from the study, it drops.
- FURRYe38Mar 27, 2020Guru - Experienced User
Had the mac book air connected to Orbi before it was damaged? If, so I would have Apple or a Apple tech look at the mac book air again to ensure its fully working.
- AATCTMar 27, 2020TutorYes the Macbook Air was able to connect to the wifi previously and was fine even when I move around my flat. Now it seems to be stucked in the study. I have also checked the Macbook Air with Apple. Everything is fine.
