Mike9676
Aug 21, 2019Aspirant
My Netgear Nighthawk CM1100 Won't Work With My Orbi Mesh System
I bought a netgear nighthawk CM 1100 router and the three unit Orbi mesh system to cover 7,500 square feet (it has one Orbi router and two Orbi satellites). The Orbi will not work with the modem. A...
- Aug 22, 2019
That worked. Thank you all!
Mike9676
Thank you, I will try this but how do you disable link aggregation on the modem?
CrimpOn
Aug 21, 2019Guru - Experienced User
Mike9676 wrote:Thank you, I will try this but how do you disable link aggregation on the modem?
This may be on page 18 of the user manual: http://www.downloads.netgear.com/files/GDC/CM1100/CM1100_All_MSOs_UM_EN.pdf
