Mike9676
Aug 21, 2019Aspirant
My Netgear Nighthawk CM1100 Won't Work With My Orbi Mesh System
I bought a netgear nighthawk CM 1100 router and the three unit Orbi mesh system to cover 7,500 square feet (it has one Orbi router and two Orbi satellites). The Orbi will not work with the modem. A...
- Aug 22, 2019
That worked. Thank you all!
michaelkenward
Aug 22, 2019Guru - Experienced User
Mike9676 wrote:
Set Orbi to Access Point?
No. That's for when you have a modem/router in front of the Orbi.
The CM1100 is a "simple" modem.
Remember, as FURRYe38 says, when setting these things up, be sure to restart your network in this sequence:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
I repeat that only to avoid any confusion with strange jargon and mystic initials. (RBR?)
