xNiinzeX
May 08, 2020Follower
My Orbi and my mode. Won’t work
Are internet is up but our modem and the orbis won’t get the internet the logos on are modem will just blink and won’t connect to wtv it suppose to
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopBe sure to read the installation guide and user manuals as well.
