STH1964
Jun 03, 2019Guide
My Orbi connected but saying "No Internet Connection".
Hi there fellow Netgear users. Please excuse my ignorance & lack of technical knowledge but is there someone out there that can help me with an ongoing problem. I have had my Netgear Orbi RBK20 ...
- Jun 04, 2019
:smileywink:
CrimpOn
Jun 03, 2019Guru - Experienced User
It might help to describe all of the equipment that is deployed, and what is connected to what. For example, the "tag" under the message mentions "Model: EX7300|AC2200 Nighthawk X4 WiFi Mesh Extender", which of course is not a component of the Orbi system. Is there a Nighthawk router somewhere?
And perhaps some more description of how these tests are conducted. i.e. the Orbi is disconnected, which means that everything now has no internet (true?), and then something is connected to the modem successfully?
STH1964
Jun 03, 2019Guide
ps: I have a tiny house outside & the reason I brought the Orbi was to push the signal out to it, which it was doing perfectly for a while, the signal was very strong going out to the tiny house but then recently the 'No internet connection' problems began but still with the strong signal, obviously when the Orbi was disconnected the wifi signal is very weak.
- CrimpOnJun 03, 2019Guru - Experienced User
Sorry, I am still confused. There is equipment connected to the modem in addition to the Orbi?
- STH1964Jun 03, 2019Guide
Yes but only the security cameras, but even before the camera was installed the problem was happening. There are 4 ports on the back onf the modem, I used 1 port for the camera/s & another port for the Orbi.
Thanks for the additional information. I understand now. There is an internet modem/router which provides service to cameras and to the Orbi. Does it also broadcast a WiFi signal? The part where I am having trouble understanding is "disconect the Orbi and internet returns." Returns to what? It can't be to something connected to the Orbi because the Orbi is disconnected. What is getting internet when the Orbi is disconnected?
