STH1964
Jun 03, 2019Guide
My Orbi connected but saying "No Internet Connection".
Hi there fellow Netgear users. Please excuse my ignorance & lack of technical knowledge but is there someone out there that can help me with an ongoing problem. I have had my Netgear Orbi RBK20 ...
- Jun 04, 2019
:smileywink:
STH1964
Jun 03, 2019Guide
Yes the main modem/router provides me the wireless wifi for the main house with the camera & Orbi connected. But for some reason when the Orbi is connected to the modem/router I can still get a strong wifi signal out to the tiny house & surroundings outside the main house but then "no internet connection" pops up on my device.
Q: "disconect the Orbi and internet returns." Returns to what?....
A: The Internet just starts working again because for some reason when the Orbi is connected it drops the internet yet Orbi signal is strong.
Q: What is getting internet when the Orbi is disconnected?
A: When Orbi disconnected the internet works fine, obviously no signal to the tiny house because my modem/routers signal won't reach that far hence why I brought the Orbi.
Sorry, But i hope I havent confused you even more.
Jun 04, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- STH1964Jun 04, 2019Guide
Hi and thank you for the options.
The house is 2 hours south of where I currently work but I am there in the weekends so i will try these options when i head down on Friday.
Many thanks for your help & i'll let you know how I go.
Meanwhile I'll check with my ISP for the MFR & Model #'s of the router
- FURRYe38Jun 04, 2019Guru - Experienced User
:smileywink:
- STH1964Sep 15, 2019Guide
Hi there,
I got my brother who's an IT guru, to come down to have a look at it after showing him the options you recommended & he knew exactly what to do.
He has made the SP modem a gateway now plus whatever else needed to be done and its working a treat now, it's been 2 months since he's changed it and no problems whatsoever, thank you again for your help.
Regards
STH1964
- FURRYe38Sep 16, 2019Guru - Experienced User
Great news. Glad he was able to help you get it all running well.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
STH1964 wrote:Hi there,
Regards
STH1964
- cw71Sep 18, 2019Tutor
Disconnect the device from the wifi network
Log into orbilogin.com
Go to Devices list
Click on Access Control
Check in the box for Allow new devices to connect
Delete the device from the list of devices not connected to the wifi network
Delete all unnecessary device from the list of devices not connected to the wifi network
Log the device back into the wifi network
Set Advance Settings to Proxy None and Connection DHCP
Try opening your browser on the device.
If still no internet, log the device back into the wifi network
Set Advance Settings to Proxy None and Connection Static -> enter valid IP Address
I tried this for my device when connected to the wifi network but no internet access and it worked.
Hope this helps.
I tried this after hours of research, trial and error, and yellingf and swearing.
- FURRYe38Sep 18, 2019Guru - Experienced User
I think the OP had a different issue with this ISP modem.
Thanks for posting though.
cw71 wrote:Disconnect the device from the wifi network
Go to Devices list
Hope this helps.
