Sktufts
Feb 25, 2019Follower
My Orbi model RBK20W
Was connected then I had to untangle plug and plugged back in... lights went pink and now no light?
1 Reply
- DickDukeApprentice
No light visible is the default state when everything is working properly. Should be a solid blue light first, but you might want to see if everything is already good.
if not, try running the setup sequence again. Should do the trick.
