TonyBalloni
Jan 29, 2024Aspirant
My ORBI RBK53 router has a different network name than my RBS50 sattelites
After a complete factory reset of my RBK53 router and my two RBS satellites my router has a different network name than my two sattellites. So I have now two WiFi networks and both working fine. How...
CrimpOn
Jan 29, 2024Guru - Experienced User
Thanks. That is a relief to hear that the factory did what it was supposed to.
How are the satellites connected to the router?
- Using the default WiFi connection?
- Using Ethernet cables?
(If so, are the satellites connected directly to LAN ports on the back of the router, or are all of the Orbi units connected to an Ethernet switch?)
TonyBalloni
Feb 06, 2024Aspirant
My satellites are connected by an Ethernet cable and switches.
- FURRYe38Feb 06, 2024Guru - Experienced User
What CAT# lan cable are you using?
What is the Mfr and model# of the ethernet switch(s) in the configuration?
