rabbit2016
Apr 09, 2019Follower
my orbi rbr 50 connection drop fix
firmware got auto updated to .44. over the weekend, i have constant internet drop issues. before that i dont have any issue since i bought it four months ago. i think i was on .210, dont know why it ...
CrimpOn
Apr 09, 2019Guru - Experienced User
rabbit2016 wrote:
I set my region to the US even though i am in hong kong
There may be differences in how radio frequencies are controlled. From what I have found, Hong Kong allows 2.4G channels 12 and 13 to be used, whereas the US does not. My guess is not being able to use channels 12 and 13 will not adversely impact you. The 5G channel availability appears to be the same. This is the table Google found for me:
(Yes, it is from Juniper Networks, but "frequencies and frequencies" no matter who makes the WiFi equipment.)
